So a couple things:
One, when I go to settings and then on apps, I can see all apps, but once I tap on an app, it fc's and says Unfortunately, Settings has stopped.
Second: when I try to install an apk, it says Package installer has stopped working and won't install.
ROM toolbox works on both fronts, I can install apks, and I can access details of installed apps, and clear data, cache, etc..
Last thing, is that there is no longer the slide ring thing that has Google search and the quick note thing when you swipe up from the home button.
Any help on any of it?
