Dear Comunity
I bought recently a Samsung Galaxy Tab, 7, running android 2.2
I come from Windows Mobile device, I was loyal for 8 years to Microsoft. I just made this shift, so far I am happy but I have some worries and questions:
1. Locale and text
under settings, locale and text > I cannot find English Ireland and Italian...
How to add these 2 locales?
2. Only 2GB for programs?
1. Locale and text
Under settings > SD card and phone storage I see:
- Internal Memory: 12.66GB
- Internal Phone Storage: 1.77GB
- External SD card 14.92 GB (this is my 16GB micro SD card which I separately bought 2 days ago)
When I use a file manager it finds a SD card and and external SD card. What does it mean? My device has 2 SD cards? One internal (14GB) and one external (16GB)?
when I install a new application from market place the device does NOT ask me where to put it (among these 3 storage areas)
I got the impression that all apps go to the smallest area (Internal Phone Storage, 1.77GB) which will surely shrink a lot, as I plan to transfer memory-intensive and consuming applications, like TTS, dictionaries (with big databases), medical dictionaries, etc.
Questions:
Where exactly my apps are installed?
Is there a way to force app to be install to external SD card? or on a storage OTHER than phone internal storage (1.77GB)?
3. My application list is now growing fast: is there a way to sort them alphabetically? Otherwise I run the risk that, with 100 apps+ , distributed in 5-6 windows, it it not easy to find them.
4. Upgrade to Android 2.3:
- when the upgrade will be available? An estimate?
- will the unit be upgradable?
- if yes, do I need to re-install all software, apps and re-sync my contact database?
Doing a backup with Titanium will solve the problem? I think not, since, after a major upgrades, most app will lose their configurations files which usually is kept within system files and these ones are cleared during and after a major O.S. upgrade. right?
5. Is there a way to sync Outlook 2010's (x32) contacts to my Android Phone? Shall I first sync Outllok 2010's contacts with my account in gmail? then from gmail to the galaxy tab? If so, how to perform the 2 steps?
6. Paid apps: my ipad, my iPhone and my wife's iphone do share my same account. So I can install a paid application on the 3 devices and this is perfectly legal (up to 5 devices, Apple told me). Is the same here, in android world? I mean, if I buy a second android device and link to my same gmail account, will I be allowed to re-download the same application which I bought recently?
7. Cable
I noted that the power charger and the USB cable are 100% identical to those of my iPad: but when I used my iPad charger + cable it does NOT charge my samsung. Viceversa also true: if I use my samsung cable it won't charge my iPad and my iPhone...Does anybody know why? are these 2 cables different in the pin mapping or else?
8.
Is there a risk of damaging samsung device if I, mistakenly, swap the two cables, the Samsung calbe and the iPad cable (they are both black).
9. Can my (wired) PC, linked via samsung cable to my galaxy, provide internet access to my Galaxy Tab?
I am NOT talking about tethering (which is: galaxy tablet providing internet access to PC), I am talking about the opposite!
10. Is there an alternative "Contacts" to the default one in the galaxy?
11. Which is a good alternative to the DEFAULT browser which is so sloooooowed compared to my iPad?
Thanks a lot and merry Xmas!
Saulo
