I've had several small bugs, which I've found really annoying and in a normal case, I would already have changed my Razr to something else. I still like this phone so much, that I can not do that.
When I just unlocked my phone, and went to the first screen to the left from the home screen, to toggle off the 3G, the widget had disappeared. Same thing with the wifi-, bluetooth-, and airplane mode toggle widgets. All other widgets I have on this screen are still visible and work exactly as they should. When I try to add these "invisible" widgets again (ie. all the "toggle" widgets), nothing happens. But when trying to add some other widget to this screen, it says that there is no room for more widgets on that particular screen (even though it appears to be plenty of room there). So somehow these "toggle" widgets still are on the screen, I just can't use or see them. I've tried rebooting the phone several times.
