It's why they don't come that way out of the box
Good is going to push and limit the manufacturers and carriers to what they can do with android.
That depends on your definition of bloat. My unsubsidised, international HTC Desire came with plenty of bloat from HTC - Stocks, Facebook, you name it. No carrier bloat, but a lot of stuff I had no use for.Easy way to get around bloatware is simply buy an international version full price and use it on a GSM carrier. Quad/penta band GSM and 3G phones would work in US GSM networks anyway.
You wouldn't want rooting to be too easy, otherwise someone who doesn't know what rooting means will root the phone and could run into all sorts of trouble.
None of that now. I generally strip junk out of custom ROMs before installing, though that wasn't necessary with my current one.
And on the topic of PCs, I would pay extra not to have bloat like McCaffee on a new PC, to save me the hassle of removing it (McCaffee is malware itself imo).
I have rooted every Android phone i've used, the last two i'd researched how to root before I even obtained the phone. I am capable of doing so without breaking the handset, but if you go through the posts on the forums where this occurs, you'll see many many people who haven't got a clue just blindly following the instructions.
The other issue is that with rooting a phone comes the possibility to remove software that your network provider placed in there as a subsidy. Maybe they've got a piece of software in there that tracks your use and sends data to them for "customer experience" analysis. You can't use the program uninstaller to remove it, but with root you can literally navigate to /system/data and delete the thing.
