Please help
I completed the steps on this website going from 2.3.4 to 2.3.3 and then rooting.
androidforums dot com/incredible-2-all-things-root/444428-downgrade-2-3-4-gingerbread-2-3-3-prepare-root dot html
Everything went great and I was rooted! Awesome. then I decided to start uninstalling applications. I uninstalled something I shouldn't have.
I know this because the system gave me an error message and the message ForceQuit kept dominating the screen I would select ForceQuit
and then ForceQuit would immediately pop back up. I had no choice but to reboot. Now the system wont start up.
How can I start over and at what stage? I dont know the terminology very well. I just followed those steps on the above website. So,
if its possible I need some instruction on where to begin. One thing to mention, I am able to get to the screen that comes up by hold the down
volume and power.
Revolutionary-
VIVO_W XB SHIP S-OFF RL
HBOOT-6.13.1002
RADIO-1.09.01.06.22
eMMC-boot
April 1 2011, 18.34.39
hboot
FASTBOOT
RECOVERY
FACTORY RESET
SIMLOCK
HBOOT USB
IMAGE CRC
Thank you in advance!
Chuck Wilson
volume and power.
Revolutionary-
HBOOT-6.13.1002
RADIO-1.09.01.06.22
eMMC-boot
hboot
FASTBOOT
RECOVERY
FACTORY RESET
SIMLOCK
HBOOT USB
IMAGE CRC
Chuck Wilson
