Someone Help!
Since208
I don't want to use metroEazy Wifi I want to use a different one but I don't know which one to use can any of you help me please! Thanks you!
Quote:
Originally Posted by Since208
Hey tiede can you help me on a wifi problem...
MetroPCS easyWifi turns on automatically and consumes memory after a while because it collects data and its been irritating me a lot.
And well I was wondering if you can help on what app can I install so I won't have to use metro's....
Thank You.!
i dont know about using a different app, 1 would just use the built in wifi on the phone, either by removing the metro wifi, or by somehow taking it off defualt
This means I would have to root my phone right?
well thanks for the info man. If I can't find a solution than ill just deal with it. Thank you.
Yep - you need to root your phone and then use an app like Antek App Manager to either freeze or uninstall EasyWIFI. The phone will then use what is built in.
