Sometimes it lags
Sdahe
Hello,
I've notice that my Galaxy S3 sometimes lags when using live wallpapers... is there a way to fix this?
several things can cause lag, even my 2K macbook can lag ever now and than, clearing ram might help, restarting might help, as long as its not lagging 24/7
I have found a few poorly written live wallpapers. Try switching to another one and see if that helps. If it does contact the author and ask them to write better code.
I have a winter/xmas one that is really laggy.
Launcher?... Im using the stock os in the galaxy s3
The stock launcher is touchwiz but you can download others such as go, apex, adw, nova, etc from the play store. If it's the same on all then it's probably a dodgy wallpaper as said above.
