D-U-R-X
turbo drinker
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Xperia Play Tips & Tricks?
4. What are the known problems with the Xperia Play?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I fix/replace my screen?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: First off, you should read this post: Battery drains at idle!
You do not have to follow all of the tips/suggestions, but the advice is sound and will help. Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Xperia Play Tips & Tricks?
A: For any Xperia Play Tips, if you use the "filter by" and select "Tips" in the sub-forum, you will get many useful tips and tricks.
What are some of the problems people have with their Xperia Play?
Q: How can I fix/replace my screen?
A: This thread has step by step instructions: How to repair Sony Ericsson Xperia Play screen
Here is a link to the Xperia Play All Things Root Guide sticky
