Help Sony Erricson Arc can't pick up home wifi
please need help here..
I am using Sony Ericsson Arc version 2.3.4
My phone is not picking up my wifi signal at home.. both compuuters at home have no problem picking up the signal though.. My phone picked up all the other weaker signal around but showing mine as 'not in range'.. any suggestion.. I tried switch it off... rebooting but still same problem.
I am
If the suggestion above didn't work, one more thing to try is to update the router's software. For this you will need to go to the manufacturer's website of your router and follow a how-to update guide if available.
I am
are you able to connect to other wifi (say at a coffee shop or your friend's?). if so, then there must be something with the setting of your home wifi.
same happened to me..Arc on Android 2.3.4
But it's ohk now... i just reset my router from Wireless mode: mixed (g/b) to Wireless mode: mixed (n/g/b).. whoilla' done.. can connect now...
hope this help..
