Help Sony X10 Mini Memory (RAM) Use
Hi,
My memory (RAM) is showing 24m available out of 165m. I thought this was because I had old app data still in memory so I did a factory reset and looked at it again using Android System Info and it still shows 24m available or 14%.
the thing is the Low Memory killer levels are 24m and I can't understand why it is so low with nothing installed.
Any ideas?
Lee
Well, the only thing I can think of is download Advanced Task Killer and check the running services, that gives you a breakdown of memory usage, maybe there you can find out exactly what is eating up your memory.
