Sony Xperia Play Variants
Ok after some reading i saw that most of them said that it had a sim slot, but some said it works and some said it didnt... o.o
"The CDMA (R800x) version does have a sim-card slot, and if you go into some of the diag screens, you can turn on GSM... "
"The R800x still has the slot for the SIM card, but it does not make use of it, it is physically disconnected and does not function under the firmware."
With the second one, im guessing you need a bootloader or something?
Thanks for the replies. The other GSM variants are a bit expensive, im just going to buy a mytouch 3G, thanks for the help though! :)
