Sony Xperia Tipo Dual FAQ's
Status
Not open for further replies.
Metroid Prime
Oil Can!!! Oil Can!!!
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Sony Xperia Tipo Dual Tips & Tricks?
4. What are the known problems with the Sony Xperia Tipo Dual?
5. Forum related questions.
6. What is root?/What does being rooted mean?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Here are a couple of things that you could consider - adjust the screen brightness, do not use live wallpapers, switch off networks when not in use (WIFI, Bluetooth, GPS), adjust update intervals for widgets (do you really need twitter/facebook notifications every half hour?). You could also consider downloading a battery monitoring app such as JuiceDefender.
Q: Are there any Sony Xperia Tipo Dual Tips & Tricks?
Q: What are some of the problems people have with their Sony Xperia Tipo Dual?
Here is a link to Tipo Dual: All Things Root Guide
Status
