Use Go SMS as your default SMS client. Once installed, it will initially show you conversations view. If you swipe the screen from left to right, it will bring you folders view. tap the menu button, and select folder settings>tick "show traditional folders". This will give you the inbox, outbox, sent and draft folders view. You cant enable this as default view AFAIK, but its always there if you need it.
