Help Sound issues with SIP applications
raisen
I have tried Linphone and Sipdroid, and both of them redirect the audio through the back speaker instead of the front one. When I try to enable the speaker mode on these apps, it makes the volume louder on the back speaker, but nothing comes from the front.
Fring works fine though - after I enable/disable the speaker mode.
I guess I'm not the only one having this problem:
Issue 341 - sipdroid - Audio is playing on the back speaker not on the earpiece - Project Hosting on Google Code
So my question is - is anyone who has a Samsung intercept successfully able to hear sounds through the front speaker using SIP apps?
Thanks
