I usually have my phone muted when I'm home but want to hear an alert from a specific contact. How can I do this? My old iPhone had this feature where certain contacts would be heard even when the phone was silent.
I found blocking mode but that's not what I want. I want basically to be notified with sound for certain contacts even if my phone is muted. Blocking blocks everything.
Okay. With sound though? I know it will still popup or show as received but didn't know if it will override silent mode. I thought blocking meant blocking all messages during a certain time period or from all contacts unless you specify who gets through. I don't want to have to turn on blocking then go through and authorize everyone of my contacts.
Well you can do it backwards... It might be a bit tedious but it will work... go into each contact that you don't want to make any noise and choose "none" or "vibrate" in the custom ring tone settings
There are apps called "My VIP Calls", "Criti Call" and another "Nights Keeper" in the play store that may fit what you are looking to do. I haven't used either so not sure how well they work.
Good luck
