Sound Settings - Volume Levels??
Hey Guys,
I'm sure there are threads about this already, but I had trouble finding any.
My question is regarding the sound/volume settings on my phone. I'm a former Blackberry user and I used to have "modes" that I could select for my phone, ie Phone Only, Low, High, etc..... On my GSIII, whenever I adjust the volume rocker, it does not save my settings for messages and what not, it just adjusts the phone call volume.....Maybe I'm just missing something, but this is incredibly frustrating...
Please Help! Is there an app that can manage you volume settings or a way to do it on the phone?
Thanks
Hey Guys,
Thanks
I highly recommend Volume Widget. It has three different sound configurations you can set. Each configuration allows you to select a different volume for ringer, voice, media, notification, alarm. The widget is 2x1. With a single touch of the widget you can change to any of the three sound configurations. I have one configuration for sleeping, one for indoors and one for outdoors.
Thanks for the tip, is this something I have to download or is it on the phone already? i couldn't find it pre-loaded?
Thanks again
