I created a sounds profile and set my ringtone, alarm, etc.
But it randomly resets to the default sounds, but still says my profile I created. Anyone have this issue or know what's causing this?
It's a really annoying issue.
If you have the file stored on your SD card I would suggest trying storing it on phone memory I had a slightly different problem solved by this. I was told it was a timing issue since access to phone memory is faster
Tried moving the files to on board storage, but then they didn't show when I tried to set them. I put them in the ringtones folder where they were on the SD card.
Won't allow me to change permissions on the folder...
The sounds seem to be sticking now, if it does it again I might just have to redownload them onto the internal storage.
