Apps Source not found Error
Hi All,
I am getting an error while running android application as "Source not found"...
Help me to sort out this..:confused:
Thanks...
I think you're going to need to be a little more specific, but sounds to me like you un-installed the app you're trying to run and the icon is stuck in your drawer.
I have used two java class where one is used to extract excel data and other is used to get specific value on screen.
when i run application using java application i got desired output and when it done by using android application i am not able to get it emulator screen(simple app.apk is installed but none of UI field comes on it)
By any chance you have made changes to package/filename/androidmanifest file/etc? I made that mistake and had that error message come up.
