Help Speakers have no audio other than notification ringtones
nprawira
My Thrive AT105's speakers won't play music or any other audio other than notification ringtone. Audio is working with earphones but otherwise I'm at a lost why the speakers won't work properly. I've turned on all of the audio settings so I think this is a software issue. Anyone out there having the same problem?
I don't have any audio problems , matter of fact my audio is very good, and louder than what I expected. What you can try is to do a factory reset , your issue might be software related but sounds like it could use a reset.
What happens if I do a reset, do I lose everything
Yep, but your contacts should be backed up to Gmail/Google if you saved them there. Also, any important files/pictures should be backed up to a computer or to whatever "cloud" you use. Apps can be restored by Google. Is your Thrive rooted?
