johngaltky
Now I have to purchase yet another array of chargers!
WTF Motorola!
WTF Motorola!
WTF Motorola!
so it won't even slowly charge off the usb port?
It will if you use one of the docks apparently but they explicitly said no usb charging. Where a dock can do it I suspect a special cable could be made to mimic it.
It will if you use one of the docks apparently it can but they explicitly said no usb charging. Where a dock can do it I suspect a special cable could be made to mimic it.
This is wrong. Some review mentioned it but it is misinformation. The charger they're looking at has a USB connector but it also has two pins that touch contacts on the underside for charging.
The charging voltage is 7.4V.
That's why. usb is ~5v. sure you could step it, but amps are probably not there on a usb cable.
Right, there's no way to connect it, otherwise you'd fry anything on the usb wire.
OK - cool. I had read the review earlier that said the dock would do a trickle charge, I thought maybe it had some special connection or something.
It's just so thin that I am afraid that I am going to break it.
