speed dial #1 from phone keypad
narflack
How do you reprogram #1 on keypad for speed dial (voicemail) I transfered data from another phone and it changed the number from my phone number to the old phone number. Searched and and cant find where its stored or anyway to change it. I now dial the person with my old number everytime i hit #1
IF you go into the phone dialer, press menu then go to speed dial, and from there you should be able to customize and edit your numbers.
Coincidentally, when I checked, my voicemail was already put as number 1, but I use my visual voicemail for messages.
Thanks, you dont have the option to customize #s 1 and 2 but i found how to change the #1 voicemail button:
Settings>call>voicemail settings. You can change the number to whatever ya want.
So without an app, there's no way to change the speed dial #2? That's what I'm trying to figure out. :P
and if it's rooted? Still haven't been able to find a solution to how to change speed dial #2 to something other then Sprint Customer Service.
