Speed of my ace
I have bought the samsung galaxy ace few months back with android 2.3.4 . I did not installed much applications also still my phone is very slow. Just i have compared with some other phones(galaxy ace) that phones are little bit okay than my ACE. Still 80MB of internal memory is free. Even it is very close...If i open a galley it will take 3 - 4 minutes to open. Recently i heard that if some files missing in the android version then also i can face the same problem. Please can any one suggest me any tips to speed up my ACE.
Thanks in advance..............................
Welcome Cavinash to Android Forums, :ciao:, look around and enjoy. If you have any questions we will guide you to the proper forum section as this is simply an introduction section and there is not much support here in this section :congrats:
Your support forum section is, Samsung Galaxy Ace
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
I hope this place will be of good use to you. Hello and Welcome to Android Forums.
Glad to have you join us, chavinash2004. :)
