Are there any tutorials out there for speeding up android phones? Like apps or tweaks?
I'm also wondering which cpu tweaking app I should use. Right now I use Franco's default app. Is cputuner and any similar apps good?
yes, to underclockOkay, thanks
You can underclock in Franco app right? You use custom profiles right?
I'm on Stock Jelly Bean, latest franco nightlie build
yes, to underclock
under OC/UV menu....set max CPU to whatever you like. this will cap it at whatever you set it at.
you can use custom profiles, but i never do. seems to handle it quite well on its own.
There's a link to a ram fixer in my Sig. I'm not going to pretend to know all the details of how it works, but basically it changes the priority of your launcher(no redraws) and adjusts your minimum free ram settings.
Well you need to be rooted for all of the tweaks people have mentioned here.
And for the v6 supercharger, if you wanted to stay stock, I'd flash a deodexed stock ROM.
If any of that sounds to complicated.... Then I dunno what to tell you lol. Research. Read up on stuff. I'm no android expert, but I'm alot more proficient now than I was 3 months ago.
Please answerThanks what's the difference between power modes and manually changing it under OC/UV menu? Do I have to configuration OC?/Uv menu if I have a power mode enabled? I have the Balenced enabled. And what kernel you use?
Google it lol
No, really.
No I was talking about answering this :
After everything is done and dalvik cache wiped for supercharger script, do I have to run supercharger again? If so, do I have to patch services. Jar again?
