ElusiveMiss
My Samsung Galaxy S3 Updated to Android 4.0.4 this morning...and now my signal, which used to be 100% in my house...has 1 bar! *Edit* Also having major battery drainage!!!
How can this be fixed?
Could you specify which carrier you're on?
Alternating to no bars....and draining my battery looking for signal
...same problem here too. For example, I have had an Evo, Evo 3d, Evo 4G LTE (i exchanged for the GS3) all had great signal strength while at my desk at work, now that i have the GS3, I have one bar or less since the update. I was thinking about contacting Samsung later today. great handset otherwise.
I'm in Pittsburgh, so no LTE updates here...probably ever. I took out the battery and it fluctuates between nothing and a bar...my battery is going down like crazy when it usually takes forever to go down 2-3%. Can updates be undone?
