Root [Sprint/Cricket] Bad battery life on CM ROM. Which ROMs have good battery life?
jackroo
I'm running the stable 10.1.2 CM and I haven't been getting good battery life. Is there a ROM that I can flash and then adjust for optimal battery life? Thanks as always for your help and suggestions!
im on the 10.1.2 stable rom and i love it, i have absolutly no issues period now.
goo man. states to install gapps. which caused all sorts of issues, GAPPS is included!
also re install the rom make sure to format dalvik, cache, and factory reset.
i didnt factory reset prior to installing and it caused issues...
after double checking twice and reinstalling stable, i had no issues.
I always wipe cache, dalvik cache, and factory reset before I flash any ROM. I may give CM another run. I'm on the peoples ROM as of now..
On Illusion 5.0 at the moment (4.3), battery life definitely can't complain. Nearly 3 hours on screen and sitting on 71% (extended battery)
PS
It's always a must to wipe all (internal not included) before flashing any rom except when your flashing a rom update.
Even then I recommend a full wipe for an upgrade to avoid any possible hiccups down the road.
