To use Bootanimation.zip
Using the root explorer, navigate to system/bin
you will be working with 2 files.
*First find a file named "samsungani" (no file extension) and rename it (ex samsunganiBAK)
*Secondly find a file named "bootanimation" (also, no file extension) and rename this file to "samsungani" without the quotation.
[FONT="]Get the bootanimation.zip file that you want to use (or create your own).
Put the bootanimation.zip in the System/Media folder.
[/FONT]
