AnDroiDHackxr
Does it exist/is it in developement, I prefer Cyanogenmod over stock android and I really want a CM12 rom for my phone, any info is greatly appreciated
There is no official cm12 for the s3. There is an unofficial cm12 for the 710, but hasn't been fixed for the 710t. There's also cm12 resurrection remix, but also hasn't been fixed for the t. Don't know if anyone tried them on the t yet. Make a backup and try is all I can say.Does it exist/is it in developement, I prefer Cyanogenmod over stock android and I really want a CM12 rom for my phone, any info is greatly appreciated![]()
Thanks for the help but I have already tried flashing this rom and I get an unknown baseband version. I have since found a 5.0.2 ROM made by OctOs specifically for the SPH-L710T and it is CM12 based, it's close enough to what i'm looking for. Thanks anyway!There is no official cm12 for the s3. There is an unofficial cm12 for the 710, but hasn't been fixed for the 710t. There's also cm12 resurrection remix, but also hasn't been fixed for the t. Don't know if anyone tried them on the t yet. Make a backup and try is all I can say.
unofficial cm12 (sprint)
Its for sprint obviously so have an APN fix handy.
Yeah octos actually has more features than cm.Thanks for the help but I have already tried flashing this rom and I get an unknown baseband version. I have since found a 5.0.2 ROM made by OctOs specifically for the SPH-L710T and it is CM12 based, it's close enough to what i'm looking for. Thanks anyway!
Yes it's a very good ROM, there are some minor issues but hopefully they get fixed.Yeah octos actually has more features than cm.
@The_Dumbest_noob hola bro me ayudarias nose , si entiendas el español?
Tengo mi Sph-L710TVPU0AOA3 I Quiero Instalar La Rom Octos No Tengo El Link Me Lo Pasarias Pl0x I Me Podrias Decir Si Es Compatible Con Mi Modelo I Que Problemas Tiene La Rom Me Serias De Gran Ayuda Ya Que La Stock Tira Fatal :/ Thanks
Try Liquid smooth. You can find it here@The_Dumbest_noob Hello bro you help me someone as friendly as I'm New Here, I have my SPH-L710TVPU0AOA3 I want to install the Rom Octos or something like a lollipop but nose if supported by my side I do not know what problems would bring Rom By install it on my terminal, so come for some tips i hope you can help me thanks guys❤✌✌
He says it does not work I have sprint sprint bro :/Try Liquid smooth. You can find it here
For the sph-L710t use the boost build.
Oh. Didn't know you had sprint. Not sure if data works on any. Try asking in the threads for the Roms.He says it does not work I have sprint sprint bro :/
