Root [Sprint/Cricket] Complete S3 Reset
scwied17
I would like to completely reset my Galaxy Samusng S3 Phone for sprint.
It is rooted.
And I would like to keep root.
Is there anyway I can WIPE EVERYTHING (memory,etc) and revert to stock but keep root?
Any suggestions/comments are appreciated!
-SCW
I would suggest just doing a full wipe from recovery and flashing the rooted stock rom.
Better than a factory reset
By full wipe what do you mean?
Could you provide me with the download link?
I'm on TWRP recovery if that changes anything
Boot into recovery and click on wipe > factory reset and then system. Go back to main menu click on install and flash a stock rooted ROM
Sent from my Nexus 7 using Tapatalk 2
Thank you all!
However, there is still a problem we are not looking at..
Will i be able to use custom roms and have my camera work?
What is the root of this problem in the first place?
hmm...
Thank you all!
hmm...
Your camera should work with custom roms just fine.
If it doesn't, try a new rom.
If it doesn't work on stock, you have a hardware failure that probably can't be fixed
