Root [Sprint/Cricket] Hopefully Quick Question
evol99
I have my s3 rooted and had the screen crack recently. I have a warranty to get it fixed but since rooting your phone apparently nullifies that would i have to unroot it before sending it in or would it not be a problem?
If you are talking about Insurance with the provider it may not be a problem as the warranty offered by Samsung does not cover a cracked screen.
if youre worried about the ins provider balking at the root access despite it being an obvious physical issue, you can unroot via Odin in a similar manner in which you rooted. Check out qbking77.com for the unroot .tar file to push via odin
