Using Blazer rom and can't get the external sd (scandisk) to mount. When I try I get a "ok to remove sd card" message. Card works fine on stock rooted SG3. Any help?
Thanks again MusicJunkie reformatting did the trick!
Glad you're up and running! The 64GB card is formatted differently than the lower capacity ones and our phones won't read it unless we have the stock kernel.
I might invest in one of those. I have a 16 GB card and thought it was big enough but I like to store ROMs on the phone/card and music so all of that takes up space, lol
