Root [Sprint/Cricket] Recovery Problems
How do I flash them using ODIN? Ive only used it once and I was following a video guide soo I dont know to much about it
No problem..here is a link for a general guide for using ODIN.
It does a better job explaining than I would.
[Guide]Odin Flash Guide - xda-developers
In your case, you only have 1 .tar file so you wont need to separate them.
Use the PDA box to install.
Let me know if you are unclear on something k? :)
Edit: sorry, just saw your edit:)
Flashed the recovery through ODIN and it worked perfectly. Went through with the rest of the guide and successfully rooted
Thanks for the help Mike :D
