ndh777
Android Expert
I picked up my phone looking to download a new ROM to it but then found that my ES File Explorer (given root permissions) was not able to view my external SD card via the mnt folder. At the same time, I was trying to back up my apps and such via Titanium Backup but it said that it couldn't backup anything because my card was full (it's default save location is my external card). It just said "Empty". I went to check my Settings to see if my card was somehow unmounted, but nope, it said it was still there. Even said that I had 11.27 GBs left out of 29 GB or whatever and gave me the usual options to Unmount and such. I pulled off my battery cover and the card was still there, so I assumed that the Android system might just need to sit for a while and cool off while off. Then I turned it back on to find that ES was still not able to view the contents of externalSDcard. So I went to my Root Browser and it too said that no files were there. I then went into my Settings and now it just says "Insert SD card".
I've had this happen before on other Android phones so I did what I normally do and hook it to my PC and reformat it. Windows found the device when I attached it via a SD card reader (the big fat kind like in your standard camera), it didn't want to format it. Windows brought up the prompt and said that it only could format 1GB so I knew Windows wouldn't be able to recognize it. I even tried formatting it via Command Prompt and typing "Format G:" and it too said there was only 1024MB to be formatted then went through trying to format and then said it failed.
I then tried pulling up Ubuntu's Disk Utility to format it. At first, Ubuntu wouldn't even correctly identify the device! Then I got the Disk Utility to recognize it and it couldn't even recognize how many GB/MB were originally on the card! Trying to format just brought up a message telling me that it couldn't do anything.
I had this happen a few times with my HTC Evo 4G OG but was able to format the card and put it back into my phone and have it work. Of course, the last time with my old 16GB card ended with it being destroyed much like this.
Please tell me that I can do something to fix this. Anything?!?! I love this 32GB Class 10 card
It was working just fine earlier today.
