[Sprint] Problem installing rom
Hello, I was wanting to install MiNCO v6 ROM...have zip file in nexus, but every time I go to install it it fails? I use ROM Manager and have Clockwork Mod recovery. I just do not know why it won't work? I notice while going through the process it checks " MD 5", md5 isn't found...does that have anything to do with it? I am really frustrated because first try I wiped OS completely so lost my JB 4.2.1 and clashed job 4.1.1 through toolkit...so I'm stuck with the old job till I can flash a new ROM...if anyone can help out with advice or suggestions I would appreciate it?? :(
Well, something must be wrong with the minco zip as I successfully installed sourcery rom to my galaxy nexus. However, now I have a problem there...I cannot connect to internet through wifi, it shows connected to router but will not connect to internet. No problem in router as pc is connecting? Does anyone have any suggestions or advice?
Here is an update....It was actually my oversite that caused the problem with WiFi as I forgot to flash Gapps after flashing ROM...everything works and JB Sourcery is an awesome ROM! I messed around with it just looking at all the MODs and settings for hours yesterday! I am one happy camper! :)
