Could you not just pull a PRL from a Sprint LG Optimus S and use the LGNPST to load it on your M?
There's an app for the Optimus S that will force it to roam even when they have sprint Signal. Tried on the M, but didn't do anything.
Well, if the app is for the Optimus S (Sprint), forcing it to ROAM even when it can connect to Sprint signal, then that means they do NOT want to connect to Sprint. They don't like Sprint signal (for whatever reason), they want something else. It probably says something like "NEVER CONNECT TO SPRINT!".
Whereas you want the exact opposite. You WANT a Sprint signal.
So, that's why this didn't work.![]()
Actually, it is doing something completely different. It is accessing a hidden menu option that tells the phone to force roaming. The launcher pro home can access it. The app doesn't work because our menus are a little different, so the app is pointing to something that doesn't exist on our phone. I found a similar hidden menu option on the M, but changing it did nothing.
You have actually looked at the source code and you know how the creator wrote the app?
Read the thread that is linked. It is by the author of the app. It is nothing more than a shortcut to a hidden menu. I looked and we have many similar hidden menus, but they are named slightly different. That is why the app will not work on the M. It also does not tell It to ignore Sprint towers. It just tells the phone to roam. There could be potential in our hidden menus, but I didn't want to ruin my phone trying to find out.
OK, then I stand corrected.
No need. Any chance you know anything more than myself about these hidden menus?
