Root [Sprint] rooted phone now having problems PLZ HELP
I just finished rooting my phone and was preparing to flash the jellybomb rom I went into twerp recovery did a backup and whipped cache dalvic cache and system whip I then had to leave because of some family issues that came up so I rebooted ( throw twerp) and my phone has been stuck on the boot up screen ( Samsung galaxy note 2) every since how do I fix this and what exactly did I do wrong that caused this to happen any and all help is greatly appreciated
thanks in advance
Chris
Because you wiped system and did not flash a rom you will need to restore the back up you made and you should be good. Im not shure how to do this but on the evo that would fix it untill you can flash the new rom. There should be a place in the recovery to restore it.
Lol thabks I guess I was in such a hurry I didnt notice that it said no ios installed are you sure you want to reboot finally got me head on right and fixed it thanks for thw help though
No problem Im still on the evo till this weekend then once i play alittle with the note ill be better at this one..LOL
