IggyAZ
I'm a beginner so please help me understand.
I have a SPRINT Galaxy S4 SPH-L720T which has firmware OA3.
When I hookup my S4 to my PC using Kies 3.0 latest build it install firmware NK1 successfully.
Then I disconnect and check update in the S4 and check firmware updates and it download and install the OA3 back again.
Which is the proper way to know which is the proper firmware?
Should I always use Kies to install firmware?
Should I keep the NK1 firmware install or divert back to OA3?
Thank you.
Thank you.
