Fabiodriven
Hello all.
First question- My email notification is the same sound as my text notification. I have a Comcast email account and I can't find any way to change this.
Second- My calendar notification is the same as my text notification. I can't find any way to change this either.
Third- When I'm writing a long text message and I get to the point that I've reached the maximum amount of characters that message can hold, the phone just won't let me type anymore. With my old phone I just kept typing and it would automatically divide the message up into two or three messages and then send them all. It seems with the Nexus I have to send the incomplete message and then start a whole new message to finish what I'm writing. Is there any way to remedy this?
I have had this phone for only 2 days now and it was bought brand new. Sometimes I have issues with the keyboard not coming up when I go to reply to a text. I touch on the little "Type to compose" screen and there will occasionally be a delay, or it won't come up at all. Then if it does come up and there was a delay I start to type and nothing appears in the message screen above the keyboard. If I back out of the message you can see what I was typing in the thread as a draft. I re-enter the message and try again and again it doesn't register in the message that I can see, but again if I back out it will be in the draft. I shut down the phone and it seems to solve the problem for a while. I've had to do this twice already.
Thank you all.
Thank you all.
