Hi all,
It would be great if there was an app that could be used to simulate sprint starting. In the sprint start, the starters says "On Your Marks", "Set" and then fires a gun. The problem is the time between "Set" and the gun firing can be anywhere from about 1-3 secs depending on the starter, so athletes need to train for this.
Simulating this could be hard, but an application could have three beeps one second apart so that the athlete knew to get into the Set position on the third beep, followed by a fourth beep of a different sound at a random time between 1-3 secs from the third beep to simulate the gun firing.
It would be ideal if you could set the number of seconds for the mimimum and maximum although I would think this would never be lower than 1 or greater than 4 seconds.
Is this hard to develop?
Thanks!
janie
Thanks!
janie
