[Sprint] Usb charging
9833
my pc has xp sp2
my sprint galaxy nexus having jelly bean 4.1.2 doesnt get detected on pc nor on my LED SONY BRAVIA , not even charging takes place...wat shud i do guys pleas help me out asap
First off welcome to the forums :)
I would suggest to make sure the USB works.
I would also make sure you have the USB drivers installed on the computer for your device.
Hope this helps :)
yes the usb port is working as other phones get detected...also have tried other usb cable..but no success.
i have installed drivers from samsung website, have installed wmp 11, n mtppk12.
i have usb connection on MTP mode on phone.
i m amazed cz phone isnt getting connected to my sony LED EX710 too..says the connections settings on phone are not appropriate...
I see you posted in the rooted section so I am assuming you are rooted. Have you tried wiping cache and dalvik? Also what ROM are you running?
no i havnt done wiping..
n sorry i m new to android , does rom version come under the build number mine is
EOS JZO54K Nightly 63
hey thanks for the concern
as u said i have wiped dalvik cache and cache....but no sign of progress.
what shud i do, i dont have official image of 4.1.2 sprint cdma,..so cant flash...
