Root [Sprint] Would love to downgrade to Sense 5.5! Help?
kar4ken
I'm very dissatisfied with some of the changes in Sense 6. I don't really want to root my phone, but will do so if that's the only way to get back to Sense 5.5. Total noob android-wise, but have lots of experience with Windows (Win7 64 bit system currently), so with a bit of help I should be OK.
HTC One
Carrier: Sprint
Android Version: 4.4.2
PRI: Version 4.38003
:confused: Don't know which tells the bootloader version, so, here's what's on the screen:
M7_WLS PVT SHIP S-ON TH
HBOOT--1.57.0000
Radio --1.01.20.0515
Open DSP--v32.120.274.0909
OS--5.03.651.3
eMMC--boot 2048MB
I haven't been able to locate an RUU for the Sense 5.5 version, but maybe someone can help. I have access to my husband's HTC one that has still has Sense 5.5, so I could copy it from there if that would work.
I would really appreciate help with this. I wish HTC would just make it easy to undo an unwanted update. Jeez, even Windows can do that.
Hello and welcome to AF
Unfortunately it's a very long process to get from 4.4.2 back to any version before that. The first requirement is s-off and the 1.57.000 hboot your on now is very difficult to get s-off. If you were to actually get s-off you could flash a previous version know as a RUU (Rom Update Utility). If you would like to read about getting s-off and flashing RUU's ...Start here
[Guide] Get S-OFF hboot 1.55 after OTA or RumRunner failed (pouring 8) - xda-developers
So does RUU work no matter what hboot as long as you are s-off?
The RUU looks for a few things .. your CID and MID must match the version of RUU your using. and with s-off you can downgrade version numbers. hboot downgrade is one of the leading reasons to get s-off. Having s-off also allows you to actually change your CID and MID so you can flash other carrier/version RUU like the Google Play Edition and the Developer Edition or AT&T to T-mobile
Ooohh so if update to the new Sense 6 update can I use an RUU to downgrade when I am s-off?
Thanks very much for the welcome and the info. I don't know what I was thinking just accepting the upgrade without looking into it. I usually upgrade my husband's phone first, as he is not tech savvy and doesn't care much about the changes. I guess I just wasn't thinking.
I'll check out your link when I get a chance. Things have been a little crazier than usual around here lately, which also accounts for my delayed reply to you.
Cheers.
Hi, I was wondering if u could downgrade your HTC to Sense 5.5 cause I hate the new one too and I would like to know where to start since there
Welcome to the forums
did you read this thread before posting ? your answer is already here look up ^
