Apps Sqlite AUTOINCREMENT
When you create the table in SQLite, just specify
create table <your_table_nam> (<key_id> integer primary key autoincrement
Then when you create a new record, for the insert statement you don't need to specify the <key_id> field. Android/SQLite will add the next available integer as the key automatically for you.
Hope this helps.
Shengxin
