Root Sqlite Vacuum and Reindex ?
MrDangerous
I thought this looked interesting and sure enough the spectrum ICS does not have sqlite3 installed. I installed it using the play store program however I didn't try to run the script as it looked like it had some hard coded /dev mount points in it.
SQLite3: phone is snappier than ever - Droid Charge - RootzWiki
Code:
#!/system/bin/sh
# Detailing Script (SQLite VACUUM & REINDEX) created by zeppelinrox.
# Credit avgjoemomma (from XDA) for the added reindex bit :)
line=================================================
clear
echo ""
echo $line
echo "    -=Detailing=- script by -=zeppelinrox=-"
echo $line
echo ""
sleep 1
if [ ! "`id | grep =0`" ]; then
	sleep 2
	echo " You are NOT running this script as root..."
	echo ""
	sleep 3
	echo $line
	echo "                      ...No SuperUser for you!!"
	echo $line
	echo ""
	sleep 3
	echo "     ...Please Run as Root and try again..."
	echo ""
	echo $line
	echo ""
	sleep 3
	exit 69
fi
echo " Commencing SQLite VACUUM & REINDEX!"
echo ""
sleep 1
echo " Please IGNORE any errors that say..."
echo "        ======"
echo ""
sleep 1
echo " \"malformed database\" OR \"collation sequence\"!"
echo "  ==================      =================="
echo ""
sleep 1
echo "   ...as they won't effect SQLite Optimization!"
echo ""
sleep 1
echo $line
echo " This may take awhile... please wait..."
echo $line
echo ""
sleep 1
echo $line
echo " Mounting RootFS and System as R/W"
echo $line
echo ""
sleep 1
fsyst=`mount | grep "/system" | grep -v grep | awk -F " " '{print $3}'`
mount -o rw,remount -t rootfs rootfs /
mount -o rw,remount -t $fsyst /dev/block/stl10 /system
echo $line
echo " On to the databases!"
echo $line
echo ""
sleep 1
for i in `busybox find /d* -iname "*.db"`; do
	sqlite3 $i 'VACUUM;';
	echo "  VACUUMED: $i"
	sqlite3 $i 'REINDEX;';
	echo " REINDEXED: $i"
done
echo ""
sleep 1
echo "           =========================="
echo "            ) Detailing Completed! ("
echo ""
sleep 1
echo $line
echo " Mounting RootFS and System as R/O"
echo $line
echo ""
mount -o ro,remount -t rootfs rootfs /
mount -o ro,remount -t $fsyst /dev/block/stl10 /system
echo ""
echo "           ==========================="
echo "            ) Everything Completed! ("
exit 0
Just bumping because I'm really interested in this but don't know if the script is right for our partitioning. Any devs have any ideas on it?
