Help Stagefright OTA - how to disable nag?
Stettin
I'm rooted with Titanium Backup. Does anyone know the process / app that I should freeze to disable the OTA notification? I only use the phone as a baby monitor anyway. I don't want to mess with anything.
update_SPH-M830_MD5ToOIl_18SEP2015
Yeah, just freeze system update apk, i don't remember the name, but its pretty straightforward.
My recommendation, if you have stock recovery, just install it, nothing bad will happen.
Apply FOTAKill.apk on /system/app directory. It should automatically remove the notification.
Do not open and install it. It's not gonna work.
