Standard Apps not compatible.....
EHMakeup
Hey there!!!
I was given a cheap chinese tablet as a gift, and I'm quickly finding that a lot of my favorite apps (netflix & hulu) aren't compatible. Is there any way to fix this? I heard a rumor I could install some software that would allow the tablet to run the apps, but I haven't had any luck finding any additional information to support that, or even where to look. Any tips, or am I just out of luck on this? Below are the specs I have on the tablet:
Model Number: SofwinerEvb
Android Version: 4.0.4
Baseband version: 1.4rc3
Kernel version: 3.0.8 bli@android-server0 #1
Build number: nulear_evb-eng 4.04 IMM76D
20120927 test-keys
Thank you in advance for any advise any one has!!!
You're out of luck. These are all over the place, and there are no developers supporting them. There is no custom software. These are basically take them as they are. Sorry
