standby battery drain?
Sgrrsh26
I have turned off so many settings but im still losing 10% of my battery while this thing sleeps during the work day. What kind of battery life are you guys getting during sleep
Have you checked to see if there's an app wreaking havoc?
How would I do that
Menu /Settings /Battery you'll see what's running on your tablet. Look for anything that has a high percentage.
Also you can install from the play store GSam Battery Monitor. Since you said your battery is draining when it should be sleeping look for what app(s) is keeping it awake.
same here just got my note 10.1 a week ago and it drains while sleeping..only thing rrunning when i look at the stats its says screen idle at 56 percent
