trancehead
Can somebody tell me what im doing wrong..
I am running Starburst ROM 1.3.2 on my Desire. (Rooted using unrevoked 1 click method)
But i cannot copy the new bootanimation.zip file across no matter what i do, the options to paste into the directory (system/customize/resource) are greyed out in ASTRO and if i try using adb it wont let me either:
C:\Program Files\Android\android-sdk\platform-tools>adb push bootanimation.zip /
system/customize/resource/bootanimation.zip
failed to copy 'bootanimation.zip' to '/system/customize/resource/bootanimation.
zip': Directory not empty
Tried to remove the old file..
C:\Program Files\Android\android-sdk\platform-tools>adb shell rm /system/customi
rm failed for /system/customize/resource/bootanimation.zip, Directory not empty
I have even tried rerooting the phone and installing the ROM & Data2SD again but no luck (Also tried before installing Data2SD in case it was that - same thing)
Anyone have any ideas what im actually doing wrong? I have even tried with the phone mounted while in recovery mode and its the same as when the phone is on and mounted in disk mode..
(I'm trying to use the Red WVGA file by the way and am renaming it once download to bootanimation.zip)
Any help appreciated!
