Apps startactivity force close
Code:
package com.danielholst.soundmixer;
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
public class LoadingSplashScreen extends Activity {
	/** Called when the activity is first created. */
	protected boolean _active = true;
	protected int _splashTime = 5000; // time to display the splash screen in ms
	@Override
	public void onCreate(Bundle savedInstanceState) {
		setContentView(R.layout.splash);
		 // thread for displaying the SplashScreen
	    Thread splashTread = new Thread() {
	        @Override
	        public void run() {
	            try {
	                int waited = 0;
	                while(_active && (waited < _splashTime)) {
	                    sleep(100);
	                    if(_active) {
	                        waited += 100;
	            } catch(InterruptedException e) {
	                // do nothing
	            } finally {
	                finish();
	                startActivity(new Intent("com.danielholst.soundmixer.DRUMPAD"));
	                stop();
	    splashTread.start();
what did i do wrong
xml here
Code:
    <application
        android:icon="@drawable/ic_launcher"
        android:label="@string/app_name"
        android:theme="@android:style/Theme.NoTitleBar" >
        <activity
            android:name=".LoadingSplashScreen"
            android:label="@string/app_name" >
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity
            android:name=".drumpad"
            <intent-filter>
                <action android:name="android.intent.action.DRUMPAD" />
                <category android:name="android.intent.category.DEFAULT" />
            </intent-filter>
        </activity>
    </application>
The activity name you put in the startActivity() method is in caps, but it is in lowercase in your manifest file. They must mat h and be tyoed exactly like the filename.
