Help Stat wont connect to network. Stuck in some mode
thelude
Can someone help me with this?
My phone rebooted and now it has the hardware info on the left hand side of the screen. I've posted a picture.
It wont go on the mobile network at all (cant make calls).
I did a factory restore, unrooted and put the stock rom on, nothing helps.
Thanks in advance
This is after a factory default? Makes me wonder if you have either some ROM/Radio/Kernel mismatch or a bad SIM card. What version of Radios, Kernel, ROM, are you using and is your SIM seen by the phone?
Also, as much as I don't like just referring people to a different forum, RootzWiki has a very active Stratosphere user base, their discussion forum is here: http://rootzwiki.com/forum/279-stratosphere/ and maybe more beneficial to you.
acejavelin -
First, Thanks for the response.
(This is in case someone finds this thread on google)
After checking the phone status, It appears the IMEI code is all zeros. This lets the 4G work (as it has SIM) but wont go onto the CDMA.
With the IMEI blanked, I dont have the special stuff needed to flash it, so I brought it to VZ and they agreed to replace it.
