V
Vaidhy
Guest
As you all know Stock Android does not support battery level in numbers in the status bar and even the so called option in KitKat is not enough. After searching the play store for hours I am tired of it. Can anyone pls tell me a simple app that will display the percentage in number in status bar. That's all I need. I don't want widget, notification bar entry or even estimate of remaining hours. All I need is the battery level. No need of even battery temperature. Anybody know a good app for that? Thanks guys!
