Accessories steinheil crystal clear bubbles on the side will they come out??
nomadpass
Will the steinheil crystal clear bubbles on the side come out eventually or do I have to keep applying till i get it just perfect?
mine has one real small bubble on the edge in one spot . i realized that this is caused by the protector hanging over the side of the glass .if you center it so the edges are completely on the glass they will go away . the rest of mine is perfect and cant be seen because the body glove case edge covers it .the rest is perfect .
there should be no bubbles when it is installed. i installed mine and there was just a couple tiny ones that came out easily. so keep trying until you get it perfect, and most bubbles are due to dust. you should be able to try as many times as you need to just be careful when peeling it up to re-apply it and don't crease it.
